[ROM] Rom MIUI8 BETA Multi for Redmi 3/3 Pro LOCKED (HU)
tomatos
Csatlakozott: 2015.01.25. 12:43
Telefonom: Xiaomi Redmi 3
Hozzászólás Szerző: tomatos »
MIUI Rom 8 BETA Update Multi - Language - MAGYAR NYELV IS VAN!
CHANGELOG / FEATURES:
On SpaceX ROM
- Support install without unlock bootloader
- Have SuperSU 2.74 Root
- Full support of Google services (CH Play, Gmail, Maps, ...)
- China Type the app, the app is not necessary
- Fix GPS navigation
- Allows custom local system (the system location)
- Optimize the amount of time information, manage Ram
- Build Miflash Rom, up through Fastboot mode or modes EDL station from any version
- And many other custom optimization, ...
GENERAL:
- Highlights:
New - App lock: Allows the application refers to all at once
Optimize - faster boot speed by 50% for the first time you reboot after the update OTA or reinstall Rom
Fix - Error lag / delay
Blurring the notification bar and status bar
Enable search in the status bar
Enable search when you swipe down from the home screen
Enable Mi Drive in File Manager
Add landscape mode for messaging applications
Show Sunrise / diving in the weather application
Integration of Google services a selective manner and optimized
Not mixed Chinese junk applications
Adding RAM processor blank from the background with less memory
Unified interface application icons (including from third-party applications)
Improved menu interface with more colors (not only every text as an official version of MIUI 8)
And the Chinese are no longer in the entire system
Video player, Music, Radio, Browser is omitted all Chinese content
Add features swipe right from the lock screen to enter applications Call
T9 keyboard support
Add Effects screen is off
Rom full Deodex
- System:
Optimize - Speed ​​fast boot times 2x for the first launch after the update OTA or reinstall Rom (supports Android 6.0)
System optimization and bug fixes, ...
- Lockscreen, Status Bar, Notification Bar:
Optimize - Floating In Caller
Fix - WI-FI details Errors on page
LINK (Locked Bootloader) - 6.6.30 :
https://www.androidfilehost.com/?fid=24591023225177388
LINK (Locked Bootloader) - 6.7.7 :
https://www.androidfilehost.com/?fid=24572369242688234
Telepítés során az ALL-t kell választani a MIFlash-ben. Én Excep data-val raktam fel és nagyon durva volt a battery drain. először azt gondoltam, hogy valamelyik app, de letörölve mindent tegnap éjszaka lemerült meging! Ez csak amolyan info, ha netán másnak is van ilyen.
Egy kis extra javítókészlet (MÉG NEM PRÓBÁLTAM DE HAMAROSAN FELDOBOM A SAJÁTOMRA IS) XDA fórumban találtam ehhez a romhoz
1. Before doing anything plz backup your main build.prop located in root/system/build.prop and save it on the PC
2. Download the modified build.prop and transfer it to phone
3 .Copy the modified build.prop and paste it (Replace) at root/system (U Can use RootExplorer for that)
4. Remember to change the permissions to rw-r-r (0644)
- Supreme Battery life (even more in idle)
- Better internet browsing & download speed
- Smoother experience
- OpenDNS DNS
- Better Microphone
- More Ram
- Better signal reception
- Wireless Tweaks
- Smoother video streaming and tweak media
- Faster Boot-Animation FPS (Just compare)
- Better call voice quality
- Game tweaks
- Qualcomm Tweaks
Módosított build.prop fájl: https://drive.google.com/open?id=0B494d ... VF4alR4T1k
További képek:
http://imgur.com/a/EsoUe
A hozzászólást 7 alkalommal szerkesztették, utoljára tomatos 2016.07.09. 16:50-kor.
tomatos
Re: [ROM] [6.6.30] Rom MIUI8 6.6.30 Multi for Redmi 3
Éjszaka volt egy durva battery drain a rommal. Sajnos még nem tudom miért. Az Android System 86%-os volt... Tesztelés alatt van a rom, szóval egyenlőre hibák lehetnek. A külföldi fórumon megkérdeztem, de még nem kaptam infot, hogy miért lehet/lehetett.
kisszoli0707
Csatlakozott: 2014.01.29. 13:22
Re: [ROM] Rom MIUI8 6.6.30 Multi for Redmi 3/3 Pro (HU Lang)
Hozzászólás Szerző: kisszoli0707 »
Próbálgatom én is,egyenlőre annyi,hogy a témák testre szabhatósága hiányzik ebből is,a nyelv úgy tűnik o.k..És persze zárt bootloader-re is pikk-pakk feltelepíthető!
Toportyan
Telefonom: Redmi Note 11 NFC
Megvan a testreszabás. A kis ember ikonra kattints bal felül
Toportyan
Egészen pontosan téma szerkesztés
Betűtipust pedig a beállításoknál lehet módosítani, nem a témában
kisszoli0707
Ha nem lennék úriember,akkor azt írnám,hogy besz.rok! :) Ott nem is kerestem,ki a franc gondolta volna,köszi szépen,valóban működik.Eddig a gyorsaságomra hagyatkoztam,ugyanis egy újraindítást követően a témák ikonra kattintva az első alkalommal általában egy másodpercre megjelent az ikonjai közt is a testreszabhatóság háromszög modulja.A további rákattintások alkalmával már se híre-se hamva. :P De az általad említett helyen valóban mindig aktív a dolog.
Toportyan
Ezelőtt is volt rá megoldás. WiFi kikapcs, témák alkalmazás adatainak törlése, akkor megmaradt egy darabig, de most már nincs ilyen probléma.
zsola
Csatlakozott: 2016.03.08. 15:48
Telefonom: Xiaomi Mi8 Lite
Hozzászólás Szerző: zsola »
Sziasztok! Nos akkor most jön a hülye kérdés. Ahogy látom ez fejlesztői rom, ha majd stabilra vált egy idő után, akkor zárt bootlouderre is fel lehet majd tenni. Remélem nem volt nagyon hülye kérdés :)
Toportyan
Ha majd jön a stabil, akkor derül ki :)
Valószínű, hogy lesz annak is zárt BL változata
muchacoado
Csatlakozott: 2013.12.15. 10:13
Hozzászólás Szerző: muchacoado »
Pro verzióra próbálta valaki? Régebbi redmi3 romoknal a pro verzióval hálózatilra nem lehetett csatlakozni.
Vissza: “Redmi 3”
