Gyurcimurci
- Csatlakozott: 2015.08.30. 08:13
Nekem most nincs redmi note 2-m semmilyen, mindkettőt eladtam az FDD-t és a prime-ot is.
Most egy ZTE v5 pro-m van, annál a cpu-z kiírja a GPU sebességet.
- tovgab
- Csatlakozott: 2014.10.05. 13:19
Kipróbáltam egy pár progit, hogy megtudjam a GPU órajelet, de mind csak annyit ír, hogy PowerVR Rogue 6200. Elkezdtem keresgélni és erre bukkantam:
"Android does not provide APIs for low level interaction with the GPU. Depending on the meaning of "Android" it is not entirely clear that there has to even be a GPU - the emulator would be a common example of something that does not, and basic ports to various development boards could be another.
It is possible, though sadly unlikely, that a given device vendor might choose to publicize some low-level programming information. Unfortunately, details of how to work with the GPU tend to be things that they hold quite closely and refuse to disclose - they argue it would give an advantage to their competitors - perhaps, but what it clearly does is prevent open source implementations of accelerated graphics drivers.
Even beyond the availability of information, there is the issue of access permission. The graphics hardware in Android is owned by system components such as surfaceflinger, and on secured devices not really made available for direct interaction by 3rd party application code.
Ultimately though, even if you could find a number it would not mean much. Clock speed of the internal engine does not tell you the number of clock cycles needed to complete an operation, the number of parallel operations which can be in process, what delays are encountered in moving data to/from memory and what caches are available, the efficiency of algorithms, etc. You might be better off benchmarking some performance test."
- megköszönték: 25 alkalommal
Nálam NOTE1-en most CPU-Z frissítés után a GPU Renderer sor után a GPU Load sor jön. (Frissítés előtt Load sem volt)
Nincs a kettő között GPU Speed...
Xmister
- Csatlakozott: 2015.09.02. 16:39
Ha megnézed itt az összes 16gb-os note2-höz mt6795m_et írnak. Igaz, hogy mind nevében td-lte van, de a leírásban fdd frekik is vannak.Gyurcimurci » 22 perccel ezelőtt írta:A td verzió specifikációja, le van írva hogy a td-ben az M-es verzió van oszt csá!
http://pdadb.net/index.php?m=specs&id=8 ... omi_hermes
Csak ezért ugye turkálni kellene a neten, nemcsak itt visítozni.
http://pdadb.net/index.php?m=search&exp ... 20note%202
Nagyon úgy néz ki,hogy hardveresen minden 16-os egyformán M-es procit kap.
CPU-Z nem olyan megbízható mint a proc/cpuinfo. Utóbbit nem a rom-tól függ.
A hozzászólást 2 alkalommal szerkesztették, utoljára Xmister 2015.10.09. 14:13-kor.
Francii
- Csatlakozott: 2015.09.02. 23:22
Csak hogy tényszerűen én is hozzátegyek valamit:
Dobozon TDD-LTE FDD-LTE
51-es végű
Akku alatt TDD-LTE
CPU: Antutu szerint MTK MT6795
Ez viszont annyiban érdekes, amikor megnyitom a Core information lehetőségnél a "more" almenüt, akkor pár másodpercig azt mutatja, hogy MT6795M, majd átvált a fennt említett MTK MT6795 szövegre...
51-es végű
Akku alatt TDD-LTE
E38fanatic
- Csatlakozott: 2015.10.07. 14:12
Csak úgy érdekesség képpen írom (most vettem észre) miközben töltőn van a telfon nem tudom a képernyőn az ikonokat rendezni. Amint leveszem a töltőről már tudom rendezni. Előtte belelépett meg remegtette abbahagyta.
Azt írta valaki az előbb, hogy az antutu a build.prop-ból szedi az infót, azt meg bárki átírja, ha akarja. A proc/cpuinfo viszont nem.
Xmister
Francii » 6 perccel ezelőtt írta:Csak hogy tényszerűen én is hozzátegyek valamit:
51-es végű
Akku alatt TDD-LTE
Nem tudnád te is megnézni es file explorer-el root mode-ban a /proc/cpuinfo -t is?
Gyurcimurci
Igen az tuti td verzió, a spec oldalon is írja a 2015051-es az td és kész.
Nekem hasonlót csinált a prime-al, ott viszont a T betű volt mögötte egy pillanatig, aztán eltűnt.
Megjegyzem ezt már csak a 7-es miui rommal csinálta, előtte masszívan ott volt a T betű.
Xmister
Az oldal az 52-eshez is td-t ír,meg m-es procit. Akkor melyik az fdd?
Arról nem is beszélve, hogy a 2015051 dobozán fdd van.
